- May 7, 2020
- 267
Need to remove the handle for my compound (leadscrew replacement). Just want to make sure this thing is not threaded on (which would be really wierd I think). Tried tapping off with a dead blow and nothing. Gonna fab up a little bearing puller type thingy. But threads would be a bad day.
Has anyone seen a threaded on handle on a lathe compound?
This is on a late 80's vintage Shen Jey 1740G (very very similar to an Eisen 1640...made by Winho). As is often the case, a lot of the Asian machinery shares a common design. The Winho parts diagram has been accurate on all the other lathe handles. For the compound, it does not show a key and does not show threads. Looks like a morse taper??
Here is an example of the cross slide handle (which does accurately show a key...part #31)
