[How do I?] Help With Cnc Laser Engraver
GrandpawB
Jan 4, 2017
4
I am looking for information on configuring a laser engraver using Mach3 and VCarve pro software programs. I have a self made CNC router I want to convert to a laser engraver. I ordered the laser, power supply and safety glasses. Now I need to figure out how to get things set up and running properly. All help is much appreciated.
I have never used a laser engraver but I would expect that it works just like a router as far as motion is concerned and instead of RPM control you need a laser Power control. I think you will find many people here ready to help out but the best way to get help is to as specific questions. Have fun and good luck.
Thanks for your reply. Maybe I asked in the wrong area. There has to be a way to tell the laser to turn on and turn off with the Z axis up and down movement.
Yes, there is a way to do that. The easiest way would be to treat it like the spindle motor and turn it on and off with a M3 and M5 in the g-code. Vcarve might be able to generate that code if there is a way to tell it that you are running a laser, not sure about that. The laser power also needs to be controlled in a range of 0 to 100% depending on your cutting parameters and materials. I think this can be handled like spindle speed in the g-code using the S (speed) parameter.
I know that Mach3 can run a laser, as far as getting it setup I'm afraid I can't be too much help. You are going to have to do a bit of research.
Thank you for your input. I was just reading an article about that. It was saying there is too much of a delay in on/off time and a Mach3 software revision would allow a M11 M12 and fix that problem. Still researching. Thanks again. Any other opinions are always appreciated. :)
There are several people on the Vectric forum that are doing it. You may want to ask the questions there.
Ray
Go to J Tech dot com and also try the Pic Sender / Pic Engrave dot com. Jtech has controllers for the laser module and lots of info online on whats needed for Mach 3 . I have a 6 watt diode blue light laser I have built up and successfully used. I used a Arduino board control system and it takes gcode generated from the Pic Engraver and Jtech programs.
Having owned some real CO2 lasers with good software I am less than impressed.... but it does work.
Jtech is a first rate company to deal with they have a plug in for the VCarve program also.
