Hi Bill n here
my problem is how to internaly tape neat tight threads I only tape in the lathe or mill holding the tape in a drill chuck Iv tried 1/3 of turn
and then back turning to brake the chip and removing the tape every 3or 4 turns to clean the tape I also use cutting compound Iv allso tried
running the lathe on slow speed 80/125 and running the tape through in one go I allways use the correct size pilot hole but have played
around with slightly tighter size holes but no real improvement Has any one tried grinding there tapes slightly undersize ?
any ideas welcom (Oh Im tapping mild steel )
Bill N
Bill N
