Hi all,
I am new to machining and recently purchased an LMS 5200 lathe. I am having a difficult time adjusting the cross slide and the compound.
I am struggling to get the cross slide to move freely but be tight enough that it does not lift, for example, on a facing cut. I have the same issue with back lash. I have to make it pretty tight to remove the backlash, but then there is too much resistance when trying to move the cross slide.
I also have a back lash type behavior with the compound, but it is not back lash in the true sense. It is caused by the way the compound lead screw is held in place. There is about 20 thousands of play that the lead screw has with the bushing (for lack of the proper word to describe it) that holds the lead screw in place.
If anyone has experience with the LMS 5200 I would greatly appreciate your advice.
Thank you,
Chris
Thank you,
Chris
