- Jan 18, 2017
- 235
Attempting to mill keyway in crankshaft that originally came with dowel pins. Question is how to be sure the hole is perfectly centered and vertical in the mill vise. The owner wants to put keyways in the crank(outlined in red) so the gear is held with more surface area to keep it from shearing the dowel pins. This crank is junk and a "test" crank to see how it goes. I have some indicators and can level it horizontally with ease, but curious how to be certain the centerline of the dowel is perfectly vertical. Hope that makes sense. Thanks.
