I have a chance to get a Monarch 10EE for under $2000. I haven't gotten to see it in person yet. I'm looking for some guidance on what to look for on the machine to make sure I've inspected it properly.
I'd like a metal lathe for my home shop and am pretty well versed in woodworking machines but new to purchasing a metal lathe.
Any help would be appreciated.
Thanks,
Christian
PS: I have a minimal amount of machine measuring tools (a small micrometer and 8in. caliper)
PPS: it comes with a 3 jaw chuck, drill chuck live center and a small tool holder 4 way or a rocker type
Hi Christian,
I don't have a lot of time right now, but I'll try to give you some quick guidance. Hopefully I can get back to you in more detail later.
It's very important to see this machine under power. I would not pay anywhere close to $2k for a 1942 10EE that I could not run unless it was absolutely pristine and you probably wouldn't be able to tell about that.
The original motor/generator (MG) drive on those machines is very robust and reliable. Typically the things that go wrong with them are quite minor, but can be challenging to find. Fortunately, I know that drive like the back of my hand and have helped lots of guys get them running. That said, if the drive isn't working or if someone had replaced it with something else, walk away from it at a $2k price. Not running, but good condition = $1500; Not running, well used = $1000.
If the drive has been replaced I would also steer away from it until you can get me more information.
The ways on a 10EE are hardened, so they can look very nice and the machine can still have a lot of wear in the saddle. The best way to check that is to use feeler gage between the saddle and the front flat way for the tailstock. You need to remove the wiper. 0.005" plus is good. If the saddle is down on the way the machine has a fair amount of wear.
I wouldn't get too upset about some wear, but adjust your price accordingly. A well worn 10EE is still capable of good work and a better machine than the average Southbend of similar size in nice condition.
If it's under power, take a 4" test cut on chunk of 1" stock. Measure the diameters along the bar. If the machine is in good condition you won't see more than about 0.0002" difference in your readings.
You can download a manual here:
http://bbssystem.com/viewtopic.php?t=1507
I'll try to get back to you later with some tips on how to run the machine through its paces. But please answer these two questions first:
- Is it under power?
- When do you plan to go look at it?
Cal
