- Aug 17, 2018
- 57
Hello all!
first of thank you so much for taking the time to read this, I am a complete newby to machining.
I've just purchased a second hand mini lathe:
"conquest super lathe" 7X14'' ,
for very cheap it comes with this set of carbine tools:
tungsten-carbide-lathe-tool-set-8mm-536001
This secondary chuck: axminster clubman sk100 woodturning chuck
ax915228
and this arbor: mt2-arbor-m33-x-3-5
Now to the crux of the matter the arbor needs to be turned to remove the wider part of the arbor just above the visible black thread. I need to remove quite a bit of the arbor to allow the arbor to nestle into the back of the chuck so the thread grips it into the chuck so I can then fit it to the lathe.
I have absolutly no idea if this can be done on the small conquest, or I need to send this peice off, or if I need to send the chuck of for a custom arbor to be made or if I can buy a arbor...
I really need some guidance, I'd love to use the arbor that the job lot is coming with but again:
I have no clue if this can be done on this lathe?
If it can what tool to use HSS/ Carbine/ Tugsten ?
Kind regards
Chris
ax915228
Kind regards
Chris
