Hi,
I just ordered my new PM1228 lathe from Precision Matthews and had a couple of questions about toolholders and inserts.
It has an AXA QCTP and I saw that they have toolholders that fit 1/2" and 5/8" tools. I am planning on making pens and working mostly in plastics (at first at least). I plan on picking up a couple quality tools and the price difference between the sizes is negligible. Is there a reason to go with 1/2" vs 5/8" tools or vice versa?
As for insert, to get started, I was planning on picking up a right hand and neutral holder, most probably a CCxx type. Based on what I have read in David Best's book, it seems that will take care of most, if not all, of what I need until I build p the courage to tackle single point threading. When it comes to inserts, most of what I have seen talks about hardened steel vs aluminum but I have not seen anything specifically for plastics or resins other than to say sharp tools work best. Would something like a CCGT meant for aluminum work well or is there a better choice? I have also seen HSS insert at AR Warner, would those be something to consider?
Thanks!
Thanks!
