Help? Remove elevating shaft- stuck
Investigator
H-M Supporter - Gold Member
Jun 8, 2016
640
Posted this question on my rebuild thread by mistake, decided to post here again.
The elevating shaft is stuck. It turns and works as it should, but I can't get it out of the knee. I have removed the bearing retainer cap but I can't pull the shaft out. I have soaked it pretty well in penetrating oil but so far it's a no go.
Have I missed something? I'm open to suggestions.
I had to persuade mine a bit with a dead blow hammer from the inside. There are a couple bearings in there that are "pressed" into a machined area of the casting.
That's what I thought might be needed. It's good to see someone else demonstrate first, lol. Thank you!
