To all of the great ones out there with vast knowledge. I am working on a Craftsman101-28990. On the Compound Screw Assembly and the Cross Slide Screw Assembly there is a washer listed #27 Part #M6-255. Does anyone have the demensions for these washers and the material they are made of. We are trying to restore this lathe to OEM Spec 100% as a project. If you could also find it in your heart to identify #16 Part #M1-92 and #17 Part #557-028 for size demensions and material. I believe that #17 will be a brass puck .125x.125 which the Microfeed Dial set screw locks against and i believe that #16 will be a #8-32 Knurled thumb screw. Any help and info would be great
