- Dec 18, 2019
- 7,430
So I'm making parts with my mini-lathe to make a gear shaft for my G0752Z. Having trouble with getting square faces parting. The 0.062" HSS blade is pulling towards the headstock. The blade was set up to be perpendicular to the spindle. The carriage is locked. So the parted piece is convex by about 1 mm. For a 2mm thick washer, this is a bit annoying. The remaining piece in the collet is concave. The G0752Z parts very nicely, with the same width blade, in it's AXA holder.
This OXA toolholder holds the blade level. The blade is ground back 7-10 degrees. Haven't measured it, but most likely 7 degrees. I have tried grinding the blade. Still pulls towards the headstock. The block that squeezes the blade into the holder, seems to be 0.25 mm undersize for the slot. I tried putting in a 0.010" brass shim to take up the slop. Blade is still pulling towards headstock. The material is just 12L14, so it cuts/parts easily. Pretty sure I am at center, and little drama, save for the non-straight cut.
Anyone have an idea or two what might make this better? Don't see any obvious wear on the holder. This parting tool used to part ok. The blade tip shows some wear. I could have sworn that I ground the blade back past that point.
