Hi,
In order to set the CPI I need an accurate known length, right? Problem is, I don't have many of those kinds of accurate tools (like calipers) or objects (like gage blocks). I have a mitutoyo 1 inch micrometer, a harbor freight 6 inch digital caliper, harbor freight parallels which seem to be manufactured to inch increments (I could for example use the 6 inch distance on them), and various small drill bits and end mills. Alternatively, I can just use the screw pitch on the table, but it's a 30 year old harbor freight micro mill, so that accuracy may also be off. What is my best option for getting an accurate CPI measurement? My best guess is milling a block less than 1 inch and then measuring its exact size with the micrometer.
