I am making a headstock spindle for my homemade lathe. Dimensions 30cm long,35mm od. 20mm id. It will be drilled and bored. Should i finish machine it and then drill and bore it in place on its own bearings? Or i rough machine then drill then finish machine using end plugs which is center drilled. Me thought that second approach will reduce distortion of the finished spindle if i remove that core of steel
