- Sep 29, 2017
- 2,293
Hallo guys.
My big Mashstroy (Bulgarian make) 1.5m lathe decided today that today is a good day to stop its power feed from working. It starts feeding,stop,go a bit and so it goes on and on and it does this with the carrige forwards and backwards and the same with the cross slide. Now I have never stripped a saddle before so I am a little out of my depth here. From what I have gathered so far is that the problem seems to be where the hex shaft in the middle below the leadscrew goes through a bushing that I think is an engagement bush of some kind? When I run the machine it sounds a bit rattly in that aria and when I stop the spindle,it feels a bit loose in the bushing. Can someone advise me if I am on the right track if I say thay I think that the bush mentioned,has a hexagonal ID and that it is starting to strip or has already. My fear is,and I think there is no way around this, that I have to strip the carriage and repair what ever is wrong. I must mention that this is a big lathe and this carriage is going to be heavy even when the cross slide,compound and top slide has been removed. Guys.....any any any advise will be welcome. I know most probably nobody here will have this model lathe,but I thik the basics is the same,so if someone has done this before, please advise me on tackling this job.
Thanks everybody.
Michael
Thanks everybody.
Michael
