A friend has this Sheldon L56 lathe. Serial TLWQ9670. I have included a few pics as well. Can you tell me about what year, specs, pros and cons, source of parts, manual. I just starting out. Mostly home automotive restoration and fixing broken farm gear.
It looks like an "L" series lathe from the late 40's to early 50's. I'm not expert on the different models, but I do know the older ones have a single lever for the thread selection. Hopefully I can attach a Sheldon Brochure from 1950-51.
ON EDIT: Looking a little closer on the second picture the name plate identifies it as an "L" model with a 56" bed. The actual useable bed length is 36"
I can not download it but that's ok I found a link to many of the manuals..I will look for that year range and see what I can find. The single lever gear select was not common in the online pics I saw so it was hard for me to find a match to place the year. And I never did see another one with this level I circled. I am looking to buy this but need to learn about it first.
The item circled is just a barrel switch AKA drum switch. New lathes seldom came with one but most used ones have had a switch installed somewhere. Note that most switch manufacturers made several different switches that may look alike from the outside but are different on the inside. Anyway, presence or absence of a switch should not have anything to do with your decisions.
The sales brochure I attempted to link is the 3rd one down on the list. In total there are 25 publications ranging from sales brochures to operators manuals, to parts manuals.
If the price is good I wouldn’t hesitate to buy it for your stated uses. It’s a good size for hobby use and your friend should be able to show you around enough to get you started. Clean it up and put an AXA quick change toolpost on and start making chips.
Lots of folks on here would love to find a machine like that, and from a friend is definitely a bonus.
It's been turning wood for a long time. Lots of dust and build up to clean. I have a friends who is a gunsmith and does a lot of lathe work. I need to spend some time with him.
