- Dec 21, 2013
- 186
Hey guys, quick question.
I need to single-point a 24-TPI thread on my Craftsman 618, the 101/Atlas model. The gear chart specifies that the gear on the lead screw is a 48-tooth gear, but it is denoted with a B - meaning that it is toward the headstock.
This makes sense, seeing as how the other gear in the setup is also set that way; it is closer to the headstock rather than farther away - denoted in the chart by F, I believe.
I had it set up previously for feeding rather than threading, so the lead screw gear was in the F position, or away from the headstock.
Well, how in the world do I get the gear closer to the headstock on the leadscrew shaft? I'm stumped. The reason why - there is a spacer of some sort between the clamp for the forward/neutral/reverse arm, held in place by some sort of pin, I think. The gear won't go on the shaft any further than the F position.
So what next? I am not mechanically inclined, therefore I decided to stop and ask first. If the spacer needs removed, is it a straight or taper pin? I tried tapping it from both directions with no result. If the spacer does need to come off and I get it, how do I retain the gear on the shaft - it will be too far down for the bolt to hold it.
Or I could be off a bit and have it totally wrong. Either way - I'm throwing this problem to the wolves of H-M!
