- Oct 21, 2014
- 2,162
Help, Need to know how to fix a problem. Have just redone the lathe. The seals and bearings were bad, Replaced all of them The when Trying to align things back up, Though I had it good, then chucked up a long piece (4 jaw chuck) to start a job and found that although I could get it set at the chuck it was way out at the other end, Though it was a bent piece of metal, Tried another few and got the same results on all of them, Then did a bit more checking and testing and found that it was always off at the same spot.
Even pulled the chuck off and checked the back pate, It was a little off on the face but not much but trued it up just in the same. the put he chuck back on, and indicated it. Seems fine when indicating it. But chuck up a long piece and it is still way out on the other end. It is almost as if the jaws are ground at an angle or something. Do not have another backing plate, to put another chuck on. Due have a 3 jaw not sure what shape the jaws are in. So what is the best way for me to get the jaws fixed to where I can get hold a piece properly. without needed about 0.100 of extra to material to get it cut properly. Oh, when I set and aligned up did get it to where I have it aligned to less than a thou over 10 inches.
any suggestions would be appreciated.
