- Oct 7, 2020
- 94
I'm a novice at machining. I've probably spent a total of maybe 3 hours actively cutting on my mil-- much longer than that setting up, of course. (It's a PM 728-VT, if it makes a difference.)
My cousin is really into building buggies and trikes and such, and he has a lathe and some other equipment. But he doesn't yet have a mill (I think he's saving up to get a CNC mill, rather than spending money on a manual.) He asked me to do some simple milling for him, and I agreed. So he sent me two pieces of "mystery steel". He spot welded them together, because each of them needs three holes drilled and bored to size, and they're supposed to match, and he thought it would be convenient to just drill and bore the holes at once, to make sure they lined up. I have misgivings about that, so if you have an opinion, feel free to chime in.
The steel he sent me doesn't seem similar to any of the steel I currently have, which consists entirely of 12L14 and 1018.
I've read cautions about not cutting mystery steel if you're a beginner, but all I need to do is drill and bore three holes. I don't mind breaking a drill or a mill tool, and I'm careful with wearing a face guard / helmet, so unless someone is absolutely adamant about it being too dangerous, I'd like to give it a go. I figure it will be a learning experience, whether I'm successful or not.
But I have no idea which tools or what speeds and feeds to use. I'm prepared to experiment, but I'd feel much more comfortable if I had a reasonable guess at what my starting values should be.
With that in mind: does anyone feel like they can hazard a guess as to what material is pictured? And/or, does anyone have a test I can do (without having specialized equipment like hardening gauges) that would help narrow it down?
My primary concern is determining if it's hardened or if it's stainless. If either of those two things are true, I might re-think the attempt, or at the very least I'll do more reading about it first. Otherwise, I don't think I'll get myself into too much trouble with a non-hardened alloy.
Any related suggestions or advice is welcome, too.
