- Jun 26, 2018
- 1,733
One of the reasons I bought this lathe, and the tooling, expensive block of aluminum and well, let's just say I spent $2500 so far to make a $50 set of velocity stacks. Its about the adventure! Anyway, the picture attached is ballpark what i want to do. How do you pull off that taper? Would tailstock offset be able to do that over such a short distance? These are about 2.5" long. ..and this part may be more challenging, but I would LIKE to have a "fin" around the inside leading around and funneling down to small end (to aid in causing a vortex sort of wind pattern.)
Thanks for the input!
