Heavy 10 Cross Slide Thrust Bearings Help
Ranger
Sep 20, 2013
21
I am asking where you get the thrust bearings for a heavy 10 cross slide and taper shaft...see attached pics
they are 3/8 ID .683 OD and around .250 high or thick..
Can any one tell me where to get these my bearing guys here can't find them and they are so small there is no bearing numbers on them
just two races and a brass cage with steel balls in it all separate pieces
Thanks for any help with this !
PS its a CL8187RB s/n 20389R...about a 1979 Tool room Heavy 10 w Taper attachment
View attachment 91643View attachment 91644
. Try Latheman2@aol.com. I I got a bearing for a 13 apron a couple months ago from him.
Try McMaster Carr. They have an online site.
Google thrust bearings or needle bearings. Lots of people sell em.
If you purchase the bearing you must also purchase new hard washers from the same supplier.
Jim
First of all let me thank the crew here for all the help
This is follow up to my issue finding thrust bearings for my my cross slide on my heavy 10 and as it turns out
also the clutch in the apron, it also has the same bearings and with my cross having the taper attachment
there are six of these in total so far. A very close alternate is available from MSC the only real difference is the SB
bearing is .250" thick and the MSC one is.280" thick but it turns out its the outside races that are different and is
you are lucky like I was then can reverse your old washer races and use the new centers ball carriers from MSC
and your golden, the other neat thing I did was to go to Ebay and buy some new chrome steel balls, they are available
in 3/32" which works perfectly with these center carriers, the carriers are made of brass in my old units with a very tiny
dimple on one side that holds the ball in place only really needed until the units is assembled. I also used this method
to repair the larger thrust bearing on the clutch assembly the one furthest back on the apron, I pushed all the 1/8"
balls out of the brass carrier and replaced them as my races were in good condition, I had to re-dimple two holes
but a small flat screw driver and a little tap with a hammer fixed that and then the new ball stays in place.
The bearings from MSC are Boston units 17195 which has a number of AC 10-1k on the package
hope this helps some other guys doing a HEAVY 10 overhaul !!!
