- Aug 5, 2015
- 14
Anyone replaced headstock spindle bearings with an upgraded version or gone to tapered bearings? PM 1022V lathe. Calls for 6202 ball bearings. Looking to improve accuracy, rigidity & hopefully quieter running.
OK, thanks. The supplied manual/parts booklet identifies the bearings as "6202" with no other info, so I am ASS-SOOMING that they are standard deep grooved ball bearings. So, with your input, looks like I'm off to doing more research.The next step up would be to go to an angular contact bearing, such as 7202, which has the same nominal dimensions as 6202.
You will need to have a way to apply some preload via shims or an adjuster ring. (I am not sure how this lathe is setup). If you have a way to control the preload you do not need "matched pair" sets.
The angular contact bearings (and tapered roller bearings) will generally not be sealed, so you may need to come up with a shield of some sort to keep out trash and keep lube in. You should probably avoid using compressed air to blow chips around.
EDIT: You might want to double check your bearing size, 6202 seems too small for a 1" ID spindle...
The PM manual also claims that these lathe already have tapered roller bearings in there.
Spindle bearingsYou might be looking at the bearings for the gears rather than the spindle bearings.
Their diagram shows the spindle bearings as 32009 tapered rollers which are 45mmx75mm. The 6202 bearings are 15mmx35mm.
Which bearings are you referring to when you say "Head stock" bearings?
