I was turning a 2 1/2 shaft by 4.25 in. down to 2 in. I turned half of the shaft down to size then did the other side but they did not match where they joined. the second halve was over cut on one side and under on the other side. hope I said this right so you guys understand. Would you say it is the head that is to one side or the chuck. The lathe is a KBC Taiwanese lathe, it seems to be adjustable but not shure . There are two bolts under the chuck that bolts to the base, and two set screws on the back side cant see any on the front or the back of the head stock. That dosent look like I could ajust from there or what do you think. Hope this makes sence to you all? Thanks Denis
