- Jun 12, 2018
- 724
There's one small set screw on the right side, one allen screw on the front and one on the back side of the tailstock. The instructions says to loosen the tailstock locking nut, then loosen the small set screw on the right, loosen the set screws on the front and the back, make the adjustment, then lock it in place with the small set screw on the right side.
I do this, but when I lock it in place with the small set screw, the tailstock moves and I'm off alignment again. I've tried locking the tailstock locking nut first, but that didn't work either. I've tried locking the 2 allens and same result. The tailstock keeps moving when I try to lock it in alignment. The left side of the tailstock would move or the right side.
Does anyone have this lathe and have the same issues?
