Has anyone seen this mod on a Craftsman109 lathe?
rammed
May 23, 2011
43
The spindle was messed up on the lathe. The last owner cranked the screw in the pulley down and messed up the spindle so I couldn't remove it. I cut the spindle in pieces to remove it. At first I thought he didn't know the screw was there to oil the shaft. When I got it apart I found the wood-ruff key missing. I found it stuck to the grime in the base of the headstock.
This headstock doesn't have a bronze bearing in the left side. someone pressed in a holder and installed a roller bearing. It's a neat mod. Has anyone seen this before?
Nope. you are breaking new ground here.
Still room for a 3-groove pulley?
The pulley still fits but just barely. You have just enough room to get the collar back in.
Are you sure that is an Atlas headstock and not a Double A? If the bed has V ways it has to be a Double A. The picture reminded me of the backside of the Double A headstock.
109 = AA
Most were branded Craftsman
That one appears to be the last version of the 109
I hate to say it, but you just can't win with a 109. The spindle isn't but about 1/2" dia and they are so prone to bend. Not intending to be the wet blanket, sorry.
