- Nov 23, 2020
- 820
Sorry for the potentially dumb question, but my 833tv is doing something a bit unexpected.
At first I realized this when moving the quil down with the drill arms. I was plunging with an end mill, and noticed that when the end mill contacted the milling surface, I could continue down with the drill handle roughly another half inch or so till the gear matched the quill itself.
Put this another way, when the quill is fully up, and retracted, I can push up on the spindle assembly, and there is about 1/8th of an inch play upwards once I overcome the weight of the quill assembly. I can also reproduce this when using the fine downfeed. Is this normal, or do I have some tweaking to do somewhere? Is there some kind of eccentric adjuster I am missing?
