OK, so bearings have different ABEC ratings. on a mill or other low speed/high load system ABEC 5 is probably a good choice. My surface grinder has ABEC 9 bearings. 650$ for a set of ABEC 7 or ABEC 9 bearings is a
great price. My bearings will cost over $2000 CAD when I go to replace them.
Getting the right bearings is essential to good surface finish, and being to hold close tolerances. If you install ABEC 3 bearings in your SG then your accuracy on your machine will be significantly impaired. I believe the cheaper options mentioned above are ABEC 3, not 5 as specified by the Bridgeport manual. in bearings, you
usually get what you pay for.
Note -- I have a BP mill that the guy who bought it from the factory always replaced the bearings using ABEC 3 bearings from a transmission supply place here. He replaced them every 5 years like clockwork over the 40 years he owned the mill. Since I don't LOVE replacing spindle bearings I've ordered a set of FAG ABEC 5 bearings for it, and am paying just about double, but they should last a lot longer than the cheaper bearings. Because of the way cutting works on a mill, the 3/5 designation won't be seen in the accuracy of your cuts.
for more information:
https://en.wikipedia.org/wiki/ABEC_scale
