Hardinge TM Vise upgrade
yugami
Jan 11, 2012
77
Anyone upgrade the vise on their TM/UM?
I have the original which is OK, but was thinking larger might be nicer. Not sure whats too big though, 5" seems like a good max to me but I'm just blindly guessing.
I think you are correct. Even that will look pretty big on that table. 6 inch would just be crazy big. May even interfere with your hand wheel.m
I still have the original vice on mine, but have been contemplating as well.
Bernie
Van Norman vise dimensions:
Swivel base bolt pattern 9"
Vise bolt pattern, length 11" width 6"
Throat capacity 2 9/16"
Vise way height with swivel base 2 15/16"
Vise way height without base 1 13/16
Jaw height 1 3/8"
Jaw width 5" (7 16" thick)
I'd get that sander away from your mill. Or,carefully cover the mill when the sander is in use.
That sander is mounted on a base with wheels and gets rolled into the center of the shop when in use. The mill usually has a sheet on it to keep the dust off. My shop is only 20' x 24' so all the small pieces of equipment are portable including a bench grinder and arbor press on one roll-away, a die filer on another and an Atlas shaper on a fourth along with horizontal and vertical band saws and table saw. Actually, only my two lathes, horizontal and BP mills, drill press and surface grinder are permanently mounted.
