Long title but it says it all.
Back story. I bought a HVL lathe. It is an old machine. According to Hardinge based on the serial number it was built in 1957. I was built in 1953 so it is a bit younger than I am. I have an operators manual for a HVL-H that was published in 1978. My machine is not much different than the one the manual was written for.
The section dealing with thread cutting, page 10 if you have a book, reads in part as follows:
"CAUTION: Lock carriage stops securely before starting to cut threads. Do not release carriage nut ( half nut ) until threading operation is completed.
With carriage at rest and quick acting handle in the forward cutting position feed the number of thousandths for each threading pass using cross slide handwheel.
Move lever H (carriage control lever) to the left and carriage will travel until it contacts the carriage stop at the headstock end of the machine. The spindle will continue to run. Carriage stops only cause only the gear box, lead screw and carriage to stop.
After every pass, withdraw the threading tool from the work with quick acting handle and return carriage to starting position by moving control lever to the right."
SO... I understand the procedure but I am left with a question, how does the carriage stop stop the carriage? I don't like not knowing how things work. Any help will be appreciated, a long winded explanation would be most welcome.
Lowell
Lowell
