- Jun 12, 2018
- 724
Took apart my PM25MV's beds. I put them back on, but I'm having a tough time with them. Specifically the gibs. Do I insert them after the bed is put in place? The X axis gib was hard to slide in and now the X axis is seized up, but I only have one side done for now. The gibs have notches on one end. Not sure if it that matters which way the notch is pointing.
Also the X axis leadscrew has different ends. Not sure which side goes where. The mill diagram shows both sides looking similar.
Any tips? I'm sure I have the gibs going to the right axis because if I swap them out, one is too thin and the other will be too thick.
