I am attempting to tap some small holes in medium steel. I am using a HSS hand tap turning the tap with a tap wrench. The problem seems to be too small a hole when I look at the charts for drill size vs tap size for specific size. I think that the last hole I attempted was a 1/2 - 13. I drilled the 27 / 64 inch hole in the steel plate and attempted to start the tap. I was using a plug tap. I started the tap and after 1 revolution, it wouldn't turn any more. I used tap magic on the tap and in the hole. After seizing the tap, I carefully backed it out and changed to a taper tap of the same size. This also would not turn after 2-3 revs. I bored out the hole to a larger size and after increasing the size of the hole I was finally able to turn the tap and cut threads. The two mating surfaces seemed to mesh well and were tight. The taps were also new and purchased from a quality machine shop supplier. These were not Chinese taps.
One other question - What does H1, H2, H3 on the taps and how do they differ? I think that it is the tightness of the threads or something like that. Can someone explain what is meant by the different grades to a novice. Thanks.
