Here is the first part of the blade brush for the band saw. This is a rotating brush driven by running against the saw blade. It will be mounted close enough to just brush the blade teeth with little to almost no pressure and clean the chips off.
View attachment 89773 These are the main parts. the 1" x 1" x 3/4" block of aluminum is drilled and bored to accept the shaft and 3 little bearings. The bearings are some high speed ball bearings I got off eBay some time ago. I got twenty of these bearings for $6. The 1" O.D. brush came from Northern Tool Co. off eBay. I got 4 brushes four $4 and free delivery. The shaft is a piece of 3/8" steel round , 1 1/2 inches long, turned on one end for the bearings and drilled and tapped on the other end for a 1/4" bolt to hold the brush on. I cut wrench flats on the shaft behind the brush to fit an 11/32" wrench.
View attachment 89774 This is the brush assembly. There are three ball bearings stacked on the shaft to support the brush. This thing doesn't turn fast and there is little to no pressure on the brush. It just touches the blade teeth to remove the chips and keep them from building up in the saw. Tomorrow I will make the little bracket to hold it on the saw.
When finished and mounted , I will post the photos and the print so anyone else may have it.
Mark Frazier
