- Dec 17, 2012
- 745
The main project is to bend a piece of copper sheet 50 mm long.
But to make this of course I need a sheet metal bender :biggrin:
So, using some scraps of the 50×5 mm iron I used to repair my deck, I began to assemble the bender.
Since it seems I have the gift of divination, the bender has a 62 cm net width, enough for the carcass of a standard 60 cm fridge (I'm sure soon or later I'll use one!).
Here I'm milling the seat for one of the hinges:
As you can see it is a hairy job!
Do you think I must use some after shave lotion as lubricant?
Anyway the surface finish seems almost decent, considering mine is a Cheapex drill press with hand movements and not a mill:
Well, my "vise on steroids" and the screw pushing down the drill handle just 1 mm every turn (1 mm is the movement of the handle, the chuck moves a lot less!) made their best.
Tomorrow I'll mill the other parts, if nobody annoys me: stay tuned!
