Not having to switch gears whenever you want a different feed rate is pretty nice.
Same here if I had it. I'd only use the others for threading.The classic Norton GearBox............
Yes it is nice not to have to change gears to alter feeds.
But I find myself using only 4 of the 10×4 selections. {hog, fast, medium, and finish}
Is the cover for the gear box easy to get off? I just picked up one of these lathes last Saturday. It's still on the trailer. It's going to need a good cleaning..... yours is looking good so farI purchased a DF1237G and a Grizzly mill/drill Friday, March 24. The mill/drill has never been used and the lathe has had minimal use. It runs and the head stock runout is under .0002. The photo of the QC gears was taken today.
Scott
There is just 4 socket head screws to remove and gently pry it off, The gear shift selector lever for turning or threading does not need to be removed, It stays on the plate.Sorry it took so long. If my memory serves me, remove the shift lever, remove 4 allen head caps screws and pull back (you may have to pry some, I think it is on pins for alignment).
Scott
