I just bought a used Black Diamond drill sharpener. The grinding wheel will need to be replaced soon. The Black Diamond drill grinder uses the side of the grinding wheel to sharpen the drill point. I have contacted Black Diamond and Rush Tool to try to buy a grinding wheel and neither one has them in stock. I started looking at Norton and CGW to find a wheel for the grinder and I came across Type 5 wheels. The type 5 wheel has a recess on one side. I can make one of the type 5 wheels fit the grinder. My question is can I grind on the side of a type 5 wheel. Below is a link to the wheel I am thinking about using. Any information would be great.
Thanks
Roger L
CGW-CAMEL 34341 7
AZ Surface Grinding Wheel for the Perfect Smooth Finish. AZ Series Surface Grinding Wheel from CGW-CAMEL is a tough abrasive specifically designed for delivering top performance during grinding processes. It ensures the best finish and consistency and shows great results on high-quality alloy...
www.travers.com
Thanks
Roger L
