Grinding Angle Plate Block with Clamps How To?
jlsmithseven
Jan 16, 2017
216
Hi Guys
I need to create 123 blocks and I need a refresher on how to align them on the angle plate to grind them. They need to be within .001 on Parallel and Perpendicular. I ground the two big faces already and want to do them both on the same angle plate if possible, but if not that's OK.
Any PDF or pictures you can show me would be awesome. I know I need one long side and one short side hanging off a top corner after using parallel bars to mount them... but I don't know how to move it after that. I know 2 clamps need to be in place and a third clamp helps me move it? Thanks in advance!
I would make individual setups for one block at a time to grind one end and one side on each block. Removing half the remaining stock and checking squareness both directions so they finish accurately, then place both on the grinder at once to finish the dimensions.
Sorry no pictures.
Jim
