Grinder for lathe tools and more
Ken_NJ
Feb 13, 2023
63
I have a Micromark 7x16" lathe and have a few blank bits but do not have a grinder to shape and/or sharpen them. The bits are 1/4 inch. What do I need to look for in a grinder to do this? I suspect I would need one with 8 inch wheels. And of course the grinder would be used for other purposes.
For starters I was looking at the Grizzly T27305. It is variabe speed. (I do have other Grizzly tools) Although the left tool rest is grooved. I would think they have an accessory that is flat which would replace it. I posed this question to Grizzly.
so first off what type of bit? HSS or Carbide they will need different wheels.
Any bench grinder or belt sander would work for 1/4" HSS lathe bits . This would depend on what else you wanted to do with it . A large 8" is nice for wire wheels and buffing besides grinding . Most people have seperate machines for each instead of swapping different wheels for different jobs .
That grinder would work. Although, a proper tool grinder will work much better:
Remember, Do not grind on the side of a regular grinding wheel as they are not designed of that and could explode. You should switch to a recessed "cup" style wheel if you want to side grind.
I'd emphasize that a "proper" tool grinder is in no way necessary. However, I'd also emphasize (as you did) that you should not grind on the side of a "regular" grinding wheel (and there's no need to for most lathe tooling).
GsT
