That is an automotive water pump shaft, a standard item at bearing houses. and used for other purposes, i used them for spindles on a multi spindle drilling machine that I built for a customer; the end shafts are soft other than a thin case hardening, so I was able to turn one end down and thread it for drill chucks, the other end was drilled with a carbide center drill to act in place of a keyway to retain the drive pullies.
