I'm still waffling about moving on from my grey AO grinder wheel on the DeWalt 6" bench grinder. Simply put, my small shop is in a Manhattan apartment, so I have space, noise, and air handling issues, most of which are pretty well under control even with my Logan 820, bench grinder, and air compressor in a 10x10 room. I grind my own HSS tools, and every time am put off by the time it takes to accomplish a tool, the dust from wheel dressing (I do a good job of capturing the actual grinding slad with wet paper toweling), and the heat. A belt sander, while perhaps ideal in some ways, would just take up space I don't have to give it, and I can't install a good vacuum system. I seriously considered a CBN wheel as a cure for all of the issues but it just didn't fit while the grinder was bolted to a shelf. Now, however, the grinder is on a vise pedestal so I could go back there. Then I saw a video where the machinist was using a white AO wheel. Did some reading, learned that it's considered to be cooler and cleaner.
Do you have experience with grinding HSS cutting tools on a bench grinder and have used both grey and white AO? Is the white better, quicker, cooler? Does it throw off the same quantity of dust in dressing? How long does it take you to grind a tool on the white wheel?
Many thanks,
Tim
Many thanks,
Tim
