Hi,
I have a Sheldon GR72P that I am trying to get the motor running using a VFD, and I need to access the front of the motor by opening the front door of the pedestal base. To gain access, I need to remove the spindle speed selector shifter. I was wondering if any of you have ever removed the spindle speed selector lever that passes through the access door. The drownings (parts list) I am looking at show a taper in and or a set screw ????? I cannot see a set screw and the hole is the same diameter on both ends, so I don't believe it's a taper pin. I've been banging on the pin with a punch and hammer for a while and it doesn't move in either direction ????? Do you have any advice ????? I would also like to better understand how the spindle speed selector works. The shifting diagram above it on the lathe shows an "in and out" position ? Does this mean the shifter is pulled in and out and then shifted forward or backward to engage different spindle speeds ????? Additionally, I would appreciate a recommendation for a source of a parts manual and operating manual ?
Best regards
Rick
Best regards
Rick
