- May 19, 2013
- 44
Hi all,
I have got me a new lathe! I found a CVA on http://www.lathes.co.uk/advertphoto/140411cva/ (after a tip from samthedog) and after a period of long consideration I decided to go for it.
I could have shared the adventure and scary part of getting the lathe home. But I wanted it home first - then tell the story!
The lathe has now landed in my shed. I need to clean it. And move it. The weight is 1700kg - or thereabout. I have got me a nice pair of machine skates so that would help. Serious considerations needs to be taken moving this thing.
I also have to decide the best strategy on shop power. There are plenty of relays and also a pump motor on this lathe. And it it wired for 380VAC. My shop has 230VAC 16Amps. I am considering to install more power in the shop - either 20Amps or 25Amp. And I could also get a rotary converter (http://www.motorsandinverters.co.uk/4-0kW-RT-Rotary-Converter-p276.html).
(Yes, I have a limited budget ……….:thinking
I will share more photos later, and the tale on getting it home!
Bjorn
Bjorn
