Hello All,
I have three questions I hope someone can help with;
I am new to the forum and to machining in general, so please bear with me. I just purchased a used Gorton, seller states it's an I 22 Mastermill. I am in the process of getting this monster picked up and brought home, I only have photos, which could be better. In the meantime; 1. I was hoping to run down the O.E.M specs, year built, and model# of machine via serial #, no joy on internet.
It has an original nameplate, Serial # 41183, 3 ph, 3 Hp, 60 Hz. It looks like it is a manually controlled spindle speed, 0- 5600 rpm, per seller. Comes w/ six 9B Hardinge collets. It's equipped w/ an Accurite III X and Y axis DRO and a supplemental motor brake ( "Short Stop"). 2. Can this machine be powered with a VFD? I only have 220 single phase, (sub panel coming soon) in my garage. If so, I will likely get a Lenze SM Vector.
3. Are Brown & Sharpe #9 the same spindle taper as the Hardinge 9B?I am wondering if finding a tool holder/adapter is going to be difficult.
I know that's a lot of info, so any help would be most welcome.
Thank You
Thank You
