- Dec 18, 2019
- 7,428
Seem to be having a little trouble setting a zero reference when using my lathe. (I thought I bored out the hole to depth, but I'm off by 0.004". Not the end of the world for this piece, but I want to do better.) What's the best way to effectively zero?
By setting a zero, I mean somehow having the tool kiss the workpiece. Setting the DRO to zero is the easy part How much material does one scrape off before declaring it's at zero? What works for you? What do you suggest? Looking for any useful tips.
I'm using a 4J, but in this case, I'm boring a hole, so I think being off center by 0.001" won't affect the depth of the cut. (Too lazy to switch to my 0.0001" dial indicator) Using a Micro 100 BB-2301600 carbide boring bar.
I hope I worded this right. It's kind of awkward to write. Just looking for a better way of setting the zero. On the delrin piece I'm off by a little bit on the depth of the holes. Is the plastic springing back? Bad zero? Something else?
