goggles for micro torch oxyacetylene welding
David S
Nov 18, 2012
1,352
Hi folks,
I am getting ready to practice micro welding in order to restore small parts using an propane / mapp oxygen micro torch. Do you know if they make auto darkening goggles for applications like this, or am I stuck with the standard #5?
Thank you
David
Search for the following on Google or other search engine: auto darkening welding goggles
You'll come up with all kinds of them. Finding one that has an adjustable dark shade might be the hard part, but they can be found.
I did but only for # 9 and above. I thought that would be too darK??
David
Hi folks,
Thank you
David
There's a Princess Auto in Kingston if you get over that way they handle a fare amount of that kind of thing, you might find something there...?:))
If you're going to try an auto-darkening welder's helmet, keep in mind that different brands use different parameters to trigger the darkening.
The cheap Princess Auto helmets use flickering infared, so a steady torch flame won't darken them. An incandescent light bulb will, so you could set one up at the back of your welding bench with a foot switch.
All of the arc wldin g helmets seem to start with a #5, so, if you wanted something lighter, you might have to keep looking.
