Good call UB.
Anybody that has ever done a "belly flop" while diving into a swimming pool knows just how "hard" the surface of a body of water can be. The
speed that a bullet travels at makes up for the lack of surface area as compared to a typical belly, when striking water. A super-sonic bullet doesn't know the difference between water, a concrete slab, or a steel plate.
Steel plates on shooting ranges are normally
angled forward so that when hit, the bullet is deflected downward and forward - AWAY from the shooter and into the earth. Setting up a steel plate in a
vertical plane results in a "return to sender" stamp upon delivery to the target - as shown in that video.
Ricochet
What actually hit "him" (his hearing protection muffs, luckily) was the equivalent of a piece of 1/2" steel bar stock, spinning end over end at a
very rapid pace! :shocked:
The .50 cal BMG ammunition he was shooting is on the far left.)
