I have been attempting to connect glass scales (5V) to an iGaging adaptor using a logic level shifter connected as shown on the TouchDRO website: https://www.touchdro.com/resources/adapters/32-bit/using-quadrature-encoders.html.
The issue I am seeing is that the axis values changes erratically, but only while the scale is moving. As soon as the scale stops, the axis display returns to zero or 0.05mm (1 count of the encoder).
I have tried all axes, and get the same result. I have tried different glass scales and get the same result. I have checked & rechecked the wiring/pinouts but so for no luck in resolving the issue.
I would be grateful for any suggestions.
