- Feb 1, 2018
- 1,867
I thought I would show you a sweet little gib straightening machine they have at DLA Mechanicsburg. You check the gib on a surface plate with feeler gages and then bend it on the screw press. I use something similar - 2 same size steel blocks sittting on a steel table or cast iron table and I use a C- Clamp to bend te gib. Use the indicator too, to tighten and release and watching the indicator until the gib bends the feeler gage amount.
