how often should the compound gibs (or cross slide) need adjusting?
I know the simple answer is "When they loosen":rofl:
But, after so many hours work? after heavy work?
The reason I ask is I broke a parting off bit and when I re-set everything and started parting again I suddenly saw the compound tilt a fraction as the bit dug in.
The gibs were very loose with heaps of slack where they were tight previously and the lock nuts were still tight.
