I'm getting ready to drill approx 60 or so 1/4-20 tap holes in a 0.775" thick 6061 AL fixture plate. My sharpest 13/64 drill bit I have is from this set: https://www.amazon.com/gp/product/B001EYU5N8
I don't have a VFD so I really don't like changing speeds, so I almost always leave my belt config at 1800 RPM (good for AL or plastics which is all I machine). Using a few of the free speeds and feeds calculators I'm arriving at 5-7IPM. However, I also saw one calculator suggest that if the depth of the cut will be more than 3 times the diameter (which is true in this case) to reduce the speeds&feeds by 50%.
I don't mind how long it takes to drill, my goal is to not burn up the bit and break it in one of the holes. I have one of those cheap mister/coolers but I generally only use it for air, but I can use WD40 too.
Any thoughts, advice?
PS. I plan to do the tapping by hand since I don't have a spindle reverse or a tapping head.
