- Jan 29, 2017
- 20
Got this mill home several weeks ago... i posted this acquisition in the Asian machine section...
I then purchased the VFD and components from Automation Direct...their tech department was extremely helpful..!!
I rummaged through my plunder heap and came up with the metal for the mounts and VFD touch pad..
The aluminum adjustable arm i found in a scrap dumpster some time ago and had an idea that i would re purpose it some day...and i did.
I placed the VFD touch pad close to the panel just in case i want to tweak the parameter settings, i felt overtime eventually the surface buttons would fail from pressing with oily fingers etc ..so the switch panel will do the functions that i feel i need.
Forward - Reverse - Jog - Speed change and Emergency stop..
Now i need to add the main disconnect and an enclosure for the VFD main unit..
