I am in the process (long process) of converting my milling maching to CNC. All the electronics are sorted, but I am still using the stock acme screws. I ordered a short length of 1" ballscrew stock (enough for the Y axis) and 2 nuts from McMaster a couple days ago; they should be here to day, which means I have to figure out what the heck I'm going to do with them. They are bare stock, so I need to machine the ends for the bearing blocks and pulleys. Thinking about how to do that, I came up with the idea of making some soft jaws for my 3 jaw, and then threading them to 4tpi so that they bite on the ball tracks, rather than the outer surface of the screw. Anybody have any opinion on this? Also, for those who have made lathe soft jaws before, do they repeat well enough to re-position the screw stock if needed?
I would try the 2J collets that came with my lathe, but I think when the previous owner put things back together it didn't quite right; I haven't torn it apart to see what is wrong, but the runout is about 30 thousandths, so that's a non starter.
